kazuo »
https://forums.nicoclub.com/kazuo-u9400.html
Sun Mar 13, 2005 6:41 pm
Ok Hi,
So my friend told me Nistech was back, so here I am with a question. ;p
Anyway, my car has this weird steering problem. I wanted some more input before I go and just randomly replace parts, hoping the problem goes away.
Whenever I make any kind of "normal" turn on the street, ex: turning left onto one street from another, or turning right from one street to another, the steering wheel does not return to the neutral position on its own. I basically need to grab the wheel and turn it all the way back into place.
The problem also manifests itself occasionally on the freeway, as well as during "spirited" (not hard) driving. Say, if I am going straight, then the road beings to veer left, if I turn the wheel left, the wheel will "stick" where I turn it, and it will only return to the neutral position if I turn the wheel back myself.
The car did not exhibit this problem before; it began abruptly one day after my car dived nose-first off the side of a road. (Don't ask) It took a few weeks for the problem to manifest itself.
The tension rod bushings are shot (they're oozing and leaking, but they were like that before the dip; I already have aftermarket replacements laying around), the tension rod bracket looks ok, as well as the tie rods.
The PS pump works fine, no leaks in the lines, no abnormal noises (grinding, whining, etc), no kinks in the lines, and plenty of fluid.
As far as the rack goes, I have no way of determining whether or not the rack is the root of the problem.
Is there anything in particular I should look for? Or, judging from my description, is the problem the steering rack?
I don't feel like just replacing parts until I find the problem, so any input is appreciated.
