Rival SE-R »
https://forums.nicoclub.com/rival-se-r-u22107.html
Sat Nov 27, 2004 2:05 pm
a little more info will help... whats been modified on the car, wheels, suspension?does it make the noise when sitting still or only when moving?
if its only when sitting still and the noise seems to not be coming from the wheel well area i would asume the pumps going out... check the steering rack for leaks around the ends as well... since i know the racks on these cars seem fairly fragile as well...
if its while moving check or the sound seems to be in the wheel well, check for rubbing marks from the time or rim contacting the body or suspension somewhere... also bushings could be making noise, or a hub bearing is starting to go or needs adjusting and the rotor is lightly touching the pad anchor (caliper bracket)
just a couple thoughts... good luck-pete
