Steering Problem
Kiven422
Car: '93 Infiniti Q45
'94 Infiniti Q45t
My steering is shot on my 94Q.
The rear wheels seem to turn fine with the steering wheel.
The front wheels don't start turning until I turn the steering wheel at least 1/4 the way, then it will somehow "catch." It also makes a clicking noise when I turn side to side while parked.
Recently I replaced the hub assembly on the left side. At first I thought the wheel bearing had gone out but now it seems to be happening again slightly and I think its because of the steering rack.
Q451990
Sounds dangerous!
I can imagine some slop with bad rack bushings, but not a 1/4 turn of the steering wheel. Time for some under-car diagnosis and part swapping...
Heath
Jorell
Car: 97 Infiniti Q41, Status - Recovered from rape
Did you resolve this???
My steering is doing the same thing. I can turn the wheel about a quarter turn now without the car changing direction. It just makes a grinding noise. It use to just make a pop when I turned it right and left before it "caught". Then two pops. Now it just loosely grinds. I had to drive it without power steering for a little while and it ruined what I think might be a bushing just behind the steering wheel?
Let me know what caused this problem for you please! My '97 Q is at a shop, and it really shouldn't be on the road for a minute with all that dangerous slop. But I don't want to pay for a whole new rack and pinion set if I don't have to.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Jorell wrote:My steering is doing the same thing. I can turn the wheel about a quarter turn now without the car changing direction. It just makes a grinding noise. It use to just make a pop when I turned it right and left before it "caught". Then two pops. Now it just loosely grinds. I had to drive it without power steering for a little while and it ruined what I think might be a bushing just behind the steering wheel?
Do you have any maintenance history for your suspension and steering system? Sounds like studied neglect led to this condition.
