Cone Junky »
https://forums.nicoclub.com/cone-junky-u86859.html
Tue Sep 23, 2008 11:51 am
Your caster can cause pulling issues also. Unfortunately if you have stock tension rods, there is no adjustment available.
I do alignments on a daily basis and have the time I have to manually adjust the toe because the steering wheel is crooked after the "computerized" alignment.
Either way, the shop that did the work needs to drive the car to verify the complaint and adjust as necessary. Sounds like they drove it on the alignment rack, aligned it, and then gave it back to you without a test drive. There is no way it should have left the shop driving crooked without an explanation.
