Steering "pop" diagnosis.
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Concord
I have the infamous steering "pop" which can be felt in the steering wheel. It happens at speeds less than 5 MPH when turning full right and slowly going over a bump.I just returned from the dealership. They were not able to duplicate "pop" until I drove with the Tech and simulated it. He agreed there was a problem. The dealership has ordered and entire steering rack for my car. I mentioned that it might be the "steering joint assy" as others have had this replaced with success. Has anyone else had the whole rack replaced?Pretty pricey part. Glad it still under warranty.
2dr_sentra
Car: 1997 200SX SE-R, 2007 Versa SL 6spd
i still have this problem, search for "klunk" under the versa section youll find more info.
Concord
Yes Ive read about other owners. What have you had replaced so far that hasn't fixed the problem?
gekko668
yeah I got one of that popping sound that i can feel and hear on the steering wheel. I took it to the dealership and they replaced the steering column. It went away for 3-4 months and now it happen again. I'm going to take it to the dealership again soon.
Shad0wXCalibur
Car: Nissan Versa SL Sedan
I had this problem and the dealer replacing the upper steering joint assembly fixed this for me. NOT the whole steering rack and NOT the LOWER joint assembly. It's a common problem much like the fuel pump.
nissantech171
Car: 07 sl versa
well its either strut mounts/bearing , lower steering shaft or the subframe but thats rare, my car had the popping i just changed the lower steering shaft it fixed it, it binds up when turning.
gorge1
Car: 2008 Nissan Versa S Hatchback
Took mine in and they replaced the upper strut bearings and intermediate steering shaft. Both of these were listed on technical service bulletins. Problem seems to be fixed.
ME18VERSA
Car: 09 nissan versa
89 5.0 mustang
i have taken mine in as well and they replaced the upper strut bearings and it solve it for me
BGDG
Car: Nissan Versa
I have the same problem CLUNKING AND KNOCKING NOISE IN THE FRONT END (front suspension) OF THE VEHICLE AND I FELT IT IN THE STEERING WHEEL. The noise was coming from passenger side. All these issues are acting when the vehicle is driving slowly and making right turn going up on the driveway or down on the driveway. I filled a complaint to Office of Defects Investigation (ODI), an office within the National Highway Traffic Safety Administration (NHTSA). If you have the same problem even without accident I'm going to recommend to file a complaint too.
PLEASE TAKE A MINUTE FROM YOUR TIME AND FILL OUT THIS COMPLAINT FORM.
You can find a link below:
http://www-odi.nhtsa.dot.gov/ivoq/
http://www.nhtsa.gov/cars/problems/
ME18VERSA
89 5.0 mustang
AHhhhhhhhhhhhh its back and i cant take it in cause i have lowering springs ....what do u guys suggest do
WaVersa
Car: '08 Nissan Versa SL CVT Tech package
It is my turn to have this problem. My Versa has only 26850 KM (not miles) .… Yesterday when I picked up my V at the dealer , I was expecting three possible speech... the Upper strut bearing OR the steering column OR we are sorry mister customer, there is no issue with your car. But no, they surprised me, they will contact me later because the bushings of the frame needs to be replaced and they are currently on back order.
NODES
Car: 2007 Nissan Versa SL (Blue)
WaVersa wrote:It is my turn to have this problem. My Versa has only 26850 KM (not miles) .… Yesterday when I picked up my V at the dealer , I was expecting three possible speech... the Upper strut bearing OR the steering column OR we are sorry mister customer, there is no issue with your car. But no, they surprised me, they will contact me later because the bushings of the frame needs to be replaced and they are currently on back order.
it is now a wide spread problem and I am glad Nissan is doing something about it.
Bubs360
Car: '09 Versa SL, '84 Vanagon
I had this problem with my '08 HB. Warranty repair was upper strut mount bearings. Haven't had a problem since.
DULCI
Car: 2008 Versa Sedan-Black
In August 2010, my 2008 Versa sedan w/ 22,000 miles starting a "clunking" sound under driver's side. Took it to my service dealership.....installed retainer on heat shield over muffler ! "Clunking" continued and spread under driver's side all the way to the rear and under trunk area. This was intermittent, sometimes very loud and I could sense a vibration. Took it back to delearship in September......they could not duplicate sound so could not repair anything. Sound continued and made me feel unsafe and uncertain as to what was happening so I took it back in October. After keeping the car for 2 days, they duplicated sound and ended up replacing left/right strut mounting bearings....saga continued and had to take it back again for SAME issue. After much heated conversation, I made contact w/ Nissan Corp and they arranged for service to take car in and work w/ Technical Support to determine problem.....they arranged a loaner vehicle(another story).......4 days later they ended up replacing Intermediate shaft. I have had the car back 1 day, let's hope this is the solution 'cause I am very frustrated. I love the Versa and I am the original owner, an "old lady" and I know the car has been taken care of. Any ideas if the problem continues ?
Is this a known problem for the Versa ?
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
yes, heard both intermediate shaft and strut bearings replaced from different people. it's not a large amount of problems, but you're not alone.
WaVersa
Finally they replaced my sub-frame and a frame link , so far, no more ‘klunk’ noise when I am turning and no more ‘pop’ sensation in the steering wheel. :woot:
JayyV09
Car: '09 Nissan Versa 1.8L SL (Super Black Hatchback)
about how long do i have to bring it in if i bought it brand new in 2009?? 3 yrs right?
Tigermack
Car: '05 Mazda3
'03 Chevrolet Silverado 2500HD Duramax
'91 Toyota MR2 Turbo
If this is a TSB... it shouldn't matter if your warranty is over, right?
xtwoonamatchx
So sorry to bump such an old thread but I am having the same problem... Any time my car sits for longer than a short period of time, and I start to move, such as pulling out of a parking spot, either left or right, I feel/hear a REALLY loud pop.... sometimes it happens when I let the clutch all the way out, sometimes when I go over a speed bump, and sometimes doesn't happen at all, although it happens more than it doesn't.
On 5/18/10 I took my car in because there was a popping noise whenever I turned fully... not as loud as this by any means, and many little ones, not one loud pop. They replaced the strut mount bearings because they were badly rusted.
My car is a 2007 with 65xxx miles on it.... the problem I'm having is that I have lowering springs, as well as other aftermarket parts. Since it is something with the steering, will they see the lowering springs and not touch it under the TSB?
I appreciate any help you guys have to offer!
Thanks!
Return to “Versa Technical Discussions”
