steering knuckle hitting turbo
The Riot Hero
hey, i got the motor in the car and the steering knuckle is hitting the turbo when you turn the wheel, i took the heatshield off and the EGR. wtf?
RobDET
Car: Cars
AIV plugged?
AllTurBo
Car: 94 red drop top w/SR
is it hitting the turbo or the o2 extension? my motor came with an aftermaket o2 extension (HKS), and that rubs agaist my steering column. Other than that there should be plenty of room, are the bolts under the steering wheel bolted up?
SpeedRacer1
Car: 1990 240SX, G35
The tube coming from the 02 extension has to be shortened to less than an inch or it will run right into the steering column.
RobDET
Car: Cars
Speed isn't that what the AIV plug is for?
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
sounds to me like your motor isn't sitting down on the pax side mount (or the mount is torn and has gotten hung up on itself) I had the same issue with my car, had to jack the motor up and re position it even though it was bolted down on both ends (my mount was torn).
Paul
SpeedRacer1
RobDET wrote:Speed isn't that what the AIV plug is for?
Yes, but why spend money and wait for an AIV (EGR) plug to arrive.
It only take 5 min to remove the pipe, cut it to about 1 inch, put a nickel in the hole to block outgoing exhaust gasses, and torque back in.
RobDET
Car: Cars
humm... sounds good to me... didn't have a motor to look at to see that it was that easy :-)
I'm STILL waiting...Needless to say my AIV plug is here and my motor is not!
240_Keyy
Car: '90 240 Fastback
lol, you don't need an AIV plug all you need is two nickles and an impact wrench :D
RobDET
Car: Cars
heh that costs way more than the plug!
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
Not if you already have an impact wrench, I got one, who doesnt? Air tools are time savers (trying taking off an old flywheel with a box wrench and 8 inch long rachet by yourself).
RobDET
Car: Cars
heck no! i used a breaker bar on mine... wasn't too too bad. I bought a new clutch instead of a compressor :-)
ItzGenX
I tried a breaker bar on mine, the whole motor spun around with it. I said screw it and put an impact to it. My compressor only costed me 109.99 shipped from harborfreight.com
RobDET
Car: Cars
that cool 109 isn't bad at all. The ones at sears (craftsman) are like 199 for the one i want....
Can i borrow yours for my swap:D :D
ItzGenX
I have a problem with lending out my tools, everytime I do so, I can kiss it goodbye :confused:
RobDET
Car: Cars
Thats totally cool. And you don't know me from adam. I'll let ya know the first time i'm out at the track...
