seang »
https://forums.nicoclub.com/seang-u122444.html
Wed Jul 15, 2009 4:20 pm
You know how motorcycles have those little metal bosses on the forks that won't let them turn too far? Well, thats what is on our HB's. They are made of metal, and when you turn all the way to lock, (either way), they are rubbing against the control arm, creaking and popping, (after all, they are metal on metal). Check it out, or if you can't find it, I'll post a pic. You should also check and fill the steering gear with some gear lube since you have the manual (non-power assisted) steering box.
