bobf645 »
https://forums.nicoclub.com/bobf645-u234870.html
Mon Apr 21, 2014 12:36 pm
Sorry about not being clearer in my description. I used the term steering kickback to describe sharp left/right movements of the steering wheel after going over significant bumps in the road at "highway' speeds, or above 55 MPH or so.
With regard to alignment, the following verbiage is out of the 2011 M37 shop manual (the verbiage is the same for both the 2 and AWD version of the M37):
< PERIODIC MAINTENANCE > [AWD]
WHEEL ALIGNMENT
WHEEL ALIGNMENT
Inspection INFOID:0000000006058169
DESCRIPTION
CAUTION:
• Camber, caster, kingpin inclination angles cannot be adjusted.
• If camber, caster, or kingpin inclination angle is outside the standard, check front suspension parts
for wear and damage. Replace suspect parts if a malfunction is detected.
• Kingpin inclination angle is reference value, no inspection is required.
• Measure wheel alignment under unladen conditions.
NOTE:
“Unladen conditions” means that fuel, engine coolant, and lubricant are full. Spare tire, jack, hand tools and
mats are in designated positions.
PRELIMINARY CHECK
Check the following:
• Tires for improper air pressure and wear.
• Road wheels for runout. Refer to WT-68, "Inspection".
• Wheel bearing axial end play. Refer to FAX-15, "Inspection".
• Transverse link or upper link ball joint axial end play. Refer to FSU-35, "Inspection" or FSU-36, "Inspection".
• shock absorber operation.
• Each mounting part of axle and suspension for looseness and deformation.
• Each of suspension member, shock absorber, upper link and transverse link for cracks, deformation and
other damage.
• Vehicle height (posture).
GENERAL INFORMATION AND RECOMMENDATIONS
• A four-wheel thrust alignment should be performed.
- This type of alignment is recommended for any NISSAN/INFINITI vehicle.
- The four-wheel “thrust” process helps ensure that the vehicle is properly aligned and the steering wheel is
centered.
- The alignment rack itself should be capable of accepting any NISSAN/INFINITI vehicle.
- The rack should be checked to ensure that it is level.
• Make sure the machine is properly calibrated.
- Your alignment equipment should be regularly calibrated in order to give correct information.
- Check with the manufacturer of your specific equipment for their recommended Service/Calibration Schedule.
ALIGNMENT PROCESS
IMPORTANT:
Use only the alignment specifications listed in this Service Manual.
• When displaying the alignment settings, many alignment machines use “indicators”: (Green/red, plus or
minus, Go/No Go). Never use these indicators.
- The alignment specifications programmed into your machine that operate these indicators may not be correct.
- This may result in an ERROR.
• Some newer alignment machines are equipped with an optional “Rolling Compensation” method to “compensate”
the sensors (alignment targets or head units). Never use this “Rolling Compensation” method.
- Use the “Jacking Compensation Method”. After installing the alignment targets or head units, raise the vehicle
and rotate the wheels 1/2 turn both ways.
- See Instructions in the alignment machine you're using for more information on this.
