steering jams up at times
joey rodrigue
Car: 1990 300zx 2+2 non turbo
bought car in july of 2017 steering was hard found air in system. bleed system, found pump got quiet steering was easy. then steering stopped returning to center when driving steering would not turn to right would have to jerk steering wheel hard then jerk back. could not tell if pump was moving fluid. ordered reman pump.still waiting on pump. drove car after letting it sit for five days.steering is working fine no problems. could problem be in the twin orifice p.s. system.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Based on the description, it sounds like you're on the right track. Update once you get the pump replaced.
joey rodrigue
will do
brian300zx
Car: 1990 300zx TT
I found my car did this when I bought it as well the pump was also super noisy because it had regular power steering fluid, I replaced it with ATF steering went back to normal and no more noise! Could also be a kink in one of your power steering lines
joey rodrigue
my son was driving the car when the steering came back. so i disconnect the twin orifice connector at rack. i believe system in in high speed mode? its been working like this for a couple weeks it has good steer feel i think we will leave it alone for now.
