steering issues
chadivaj
Car: ...
i have a 95 240sx se.
my problem is there is something worng with my steering
kind of hard to explain, but say if i entered a left curve, half way through my car will jerk to the left, and then when i exit my car will jerk back to the right...the faster i go through the curve the larger the jerk. also when this happens my steering wheel might by turn 40degrees, but the car will going straight, then all of a sudden the car will jerk to which ever way the steering wheel was turn, then everything goes back to normal...
i was reading about tension rods, and i think this may be the answer, but i want to know if anyone knows for sure whats wrong
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
sounds like a rack and pinion problem.
janda240sx
Car: 1995 240sx se
My 89 was doing the same thing. It was my ball joints though. My 95 se is doing it now and i can't figure it out. I'm checking everything again this weekend. I'll let you know if i find nething. Let me know if you figure it out.
