Steering issue
dillusion13
Hi guys, I have an issue with my steering. Let me describe whats going on. If I back out of a driveway onto the street, when level with the street, my steering wheel is straight. As soon as I start driving, the steering wheel starts to turns about a 1/4 turn...all while the car continues to go straight. While on the freeway, if I hit a big dip, steering wheels also shifts, but car still goes straight. I had the rack and pinion rebuilt, have new inner and outer tie rods.....can't figure out the issue. I'm thinking the shop didn't rebuild the rack properly? Or is there something else that could affect steering like this? Oh, and its on a 92 240sx SE.
r3v_v3ng3
Car: 91 fastback ka-t
your steering wheel probably wasn't straight when you install the rack and pinion
skydragoness
Car: 03' 350z Touring 6spd
92' 240sx 60k survivor :)
Did you get the car aligned after doing all this? You're supposed to.
Cone Junky
Car: S13 fastback
BMW e46 328i
It does just sound like a toe issue. Have the shop that installed the rack re-align.
dillusion13
I had my wheels aligned, but when ever it gets aligned, its relative to where the steering feels like being. As soon as I start driving, the wheel shifts. About the rack, do I uninstall it and re-install it with wheels straight?
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
You could just take the steering wheel off with the wheels straight and put it back on straight.
The rack doctor
Car: I fix um
Not that I would know the answer to this (he he he) but did you replace the bushings when you installed the rack ? also the steering knuckle may be off a spline and not completely tight but then your wheel wouldn’t come back on center. The inner tie rod may have blown out as well. Or lastly you could have a worn or broken tooth on the power piston in the steering gear itself.
Be well Rack doc
krash133
When you hit a bump and the wheel turns slightly but the car stays on course is a natural thing called bump-steer. Most cars have it and it relates to suspenion/steering geometry, not a big deal. The whole backing up/going forward thing sounds alignment related, if you haven't had one done after the work to the rack that would be a wise place to start.
The rack doctor
Car: I fix um
krash133 wrote:When you hit a bump and the wheel turns slightly but the car stays on course is a natural thing called bump-steer. Most cars have it and it relates to suspenion/steering geometry, not a big deal. The whole backing up/going forward thing sounds alignment related, if you haven't had one done after the work to the rack that would be a wise place to start.
I believe the term you are looking for is the Aikerman principal !!!!!!
desertdustr
Car: 280zx/240sx
Is there a possibility that your vehicle has the optional "rear steer" assist?
