Steering Issue... I need help!
Nissan 350z / Nissan 370z technical discussion forum: Maintenance, performance, installations, modifications, how-to's and troubleshooting.
pschultz91
Car: 2003 350z Touring w/Nav
I am getting some serious clunking noises whenever I turn the steering wheel and not to mention horrible bump steer and loose steering. I have already changed out my Compression rod bushings, Lower control bushing with white line bushings I also changed my inner and outer tie rods about two years ago. that seemed to help for a while but not anymore. So it leads me to the steering rack... yay! Do you guys think i need a new or reman steering rack or could i get away with just doing a rack seal kit. Any help will be greatly appreciated.
Q451990
:welcome: to NICO!
No clue if the rack is the issue - but while you're looking - see if there's a u-joint that connects the steering column to the rack. I had one of the fail on my Q years ago, and it caused all sorts of steering weirdness.
Also check out the service manual at http://www.nissanservicemanual.com for more info...
Heath
pschultz91
Q451990 wrote::welcome: to NICO!
Heath
I will definitely check that out as soon as possible. I hope that could be the simple fix im looking for!
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
That U joint was also a fairly common issue on the Z31 and Z32 and was gonna be my suggestion.
pschultz91
I will be jacking the car up tomorrow to check the u joint! I will get back to yal hopefully tomorrow! thanks again!
Nelelectric
Car: Nissan 350z
Can anybody help me, I need the inner tie rod torque, thanks.
Return to “350z / 370z Technical”
