srini006 »
https://forums.nicoclub.com/srini006-u46021.html
Mon Apr 28, 2008 8:03 am
Hello,
I would like to get some insight from the experts in this forum before I can go for any service needed on these issues I'm having. When I got 105 K miles service (J 30 - 1996) done 2 years ago, the service technician had recommendation for water pump replacement. I had my timing belt changed at that time. They didn't tell me about water pump replacement but had written on my final invoice.
During the last 2 years, I have experienced few issues which weren't major but want to make sure if it's just due to the age of the car.1) I see water dripping underneath once a while. I checked my coolantlevel and it has good level in the reservoir.2) My steering gets very hard once a while. I have been told to change the complete steering rack as the steering fluid was leaking and was given 1000 dollars invoice by Tiresplus. I searched on the forums and found that it's usual on an aging car and had recommendations to use leak proof steering fluid to stop any leakage but it gets once a while. It does get normal when I try to use it in the next 5 - 10 minutes.
Any suggestions/recommendations that I can do myself to make sure that there is no major damage occured that's causing the problems.I have attached few pics from underneath side of the car engine
Thanks in Advance
