dcg129 »
https://forums.nicoclub.com/dcg129-u77311.html
Thu Jan 10, 2008 5:09 am
You might have messed up your CV joint which might be the grinding sound from the bearings or the caliper/rotor damage. Sounds serious. If you are able to, it sounds like you would be able to ollect collision damage if you want, I hit a manhole cover years ago and 3 months later I was told I did frame damage. the insurance co paid the bill - the deductable. It might be worth your while to have a collision shop or a large national car repair co look at it for free to get a good look at it. The pulling is usually brake caliper problems but a miss aligned /damaged front can do similar things some time. You definately need a wheel alignment. Get it done soon. A hard break on a slippery road will put you in a spin or skid into someone real fast. Been there, done that and have the tee-shirt
