Steering gear help!
kibatheloanwolf
Car: 1987 D21 2.4L with a 5 speed manual trans
2010 Camry 2.5L with a 6 speed maunal trans
Okay folks I recently got ahold of a 1990 Nissan HB 4x4 and seem to be having some issues steering above 40 mph it gets too loose.
I need help replacing the powersteering gear on this thing.. anyone done it before? if you have any tips?
mrecoolgar
Car: 1990 Hardbody Reg Cab 2WD 2.4 5SP
On some boxs, there is an adjustment bolt.
This bolt is locked by a nut.
Loosen the nut, tighten the bolt slightly, tighten nut.
Hope this helps.
seang
Car: Ford Fiesta ST
Set the external adjuster with the steering centered or else it will bind.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Check linkage before messing with the box. I'd also replace the idler arm bushings with bronze versions if you plan on keeping the truck.
kibatheloanwolf
Well i did a carfax on the thing and found out that a car had slammed into the passenger side destroying the steering box the guy tried to fix it himself and failed.... photos soon to come
RT22
Car: 1991 nissan hardbody
Time for a junkyard trip, get a used box that has not been hit and it may help and will be cheap.
