Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Sat Jul 19, 2003 8:41 am
If you don't mind replacing your steering rack [$1200] don't bother to fix............road dirt/water gets in and destroys the rack seals fast!
See why you get the oil changed somewhere every 90 days whose techs know what to look for!
If they are both the same age, change both as the labor will/should be less in the long run............good time to check inner and outer tie rods and ends for play and how are the rack support bushings. How are kingpin bearings, upper links, tension rods swaybar bushings ....................all the things that wear and need changing.
