I pulled out the steering rack this weekend and found my u joint going right into the steering rack is shot. Even worse than my driveshafts. The U Joint is a 15mm (.590") Cap diameter and 40mm (1.575") width and is staked into position. I found the Nissan Part number for the entire assembly is 48080-0W00A, and is about $180. I called my local Driveshaft place and they stated they no longer do steering u joints and since this u joint is staked in, there is a high failure rate if they did replace it. So they didn't want to do it. The U joint I need to replace is the one circled in red. What have you guys done to replace or do I just need to pony up $180 for an entire new assembly. I have searched the internet to find nothing.
