steering column ?
spitz7985
Car: HICAS S13
How do I get the steering column off the steering gear? I unbolted the first bolt up from the steering gear on the column but it's still on there really good.
Also, any recommendations on getting a stubborn tie rod end out of the knuckle? I got the key and bolt out, but the damn stud won't come out of the knuckle. I got it soaking in PB Blaster right now. Is it okay to bang the hell out of it with a rubber hammer?
NISTECH
why are you pulling your rack out? are you replacing it?
navysnail
to remove the tie rod, dont hit the bolt, hit the eye it goes through on the side (you are hitting the part of the hub that it pushes and pulls on.)
spitz7985
Car: HICAS S13
NISTECH wrote:why are you pulling your rack out? are you replacing it?
Yes
NISTECH
wack the knockle where the tie rod is bolted in a few times with a solid hammer,it should just pop out. to realease it from the coloum just undo the bolt holding it to the rack input then undo the rack mount brakets and slide the rack out of the clamp,you need to completely remove that bolt too not just loosen it.
spitz7985
Car: HICAS S13
Steering column won't let go, tried heating it, tried prying it. IDK what to do. I'll go back out and give her hell in a little bit. Any tips?
NISTECH
The rack input shaft should just slide out of the joint clamp once the bolt is removed you should not need any force at all. You will not be able to lift the joint off the rack if thats what your trying to do. the joint bolt is like the pinch clamp on a bicylce seat. once you remove the bolt you should be able to spread the joint clamp slightly with a screw driver to slide the rack out. Although that is not usually nessesary as it will just fall out in most cases.
spitz7985
Car: HICAS S13
NISTECH wrote:The rack input shaft should just slide out of the joint clamp once the bolt is removed you should not need any force at all. You will not be able to lift the joint off the rack if thats what your trying to do. the joint bolt is like the pinch clamp on a bicylce seat. once you remove the bolt you should be able to spread the joint clamp slightly with a screw driver to slide the rack out. Although that is not usually nessesary as it will just fall out in most cases.
It's not sliding out. I have the bolt out, I tried the screwdriver thing. But I was trying to push the column up.
How do you move the rack downward, away from the column? The subframe is right there, and I can't get it around the subframe because of the steering column.
NISTECH
once you have the rack mount bolts removed you need to twist the rack to get it off. I do believe on the 240 you also need to do unbolt the motor mounts from the subframe and lift it up to give you room to extract the rack from the car.
spitz7985
Car: HICAS S13
NISTECH wrote:I do believe on the 240 you also need to do unbolt the motor mounts from the subframe and lift it up to give you room to extract the rack from the car.
s13sr20chris
i used a prybar and pryed my steering intermediate shaft up off the rack and the rack down. its not too easy.
NISTECH
I dont think he liked my answer.
How did you get it back on??? you couldnt of pryed it.
spitz7985
Car: HICAS S13
Okay, NISTECH, my steering rack is now hanging by only the unbolted steering column. There is a flathead screwdriver sticking in the clamp seperating it. I had my whole upper body hanging from the steering rack and the column still did not let go. Any ideas? Thanks.
NISTECH
is it like heavily rusted or what. if the rack is free dangling and not sliding off the colum joint something is serioulsy wrong. Do you have a digital camera to snap a shot of it and post the photo. maybe you and I are not on the same page here or something. It should not be that difficult to slide it off. the hardest part is manuvering it around to get it to slide off since it is in tight quarters but by lowering your front sub frame you eliminated that problem.
s13sr20chris
heck yeah, pry it off and pry it on. if i had my druthers it would just slip off. that doesnt usually happen.
NISTECH
druthers???:confused:
spitz7985
Car: HICAS S13
Yes, that splined shaft that comes out of the rack and pinion unit is pretty rusted. I don't know how pics will help, but I'll get some hopefully tonight but more likely tomorrow.
Actually, I didn't lower the subframe, I raised the engine and bellhousing by unbolting one motor mount and jacking it up. But yeah, the rack is free dangling by the steering column. I'll try to get those pics.
s13sr20chris
NISTECH wrote:druthers???:confused:
some musical i saw as a kid. darn line is still stick in my head. i believe its short for "i'd rather". the intermediate form may have been i'd ruther. somehow we now have our "druthers" meaning our preferences.
NISTECH
Have you saoked it in PB blaster or whatever that rust penetrant is?
The pic was to confirm that what you are trying to seperate is what I am telling your to seperate since I have never had one actually weld it self on. But I asked if it was rusted since you are from the part of the country that virtually destroys cars with rust. Remember I am in california I hardly ever have to deal with rust.
spitz7985
Car: HICAS S13
Alright, got it off.
It was basically welded on with rust. I ended up going up to where the U joint clamps onto the column, unbolted that, stuck a couple of 1/2" drive extensions down onto the U joint from under the hood and pounded on the extensions with a 5 lbs hammer and 20 hits later, the U joint came off, then I held the rack to the ground and pounded off the U joint from the rack. Thanks for your help NISTECH. Rust is a *****.
NISTECH
DAMN DUDE!!!! I have no desire to work under those conditions. I feel for you guys back there that deal with it every day. Sorry for the confusion in trying to help ya guy.
s13sr20chris
yeah, rust sucks. we get a little here in va but not a whole lot. i will say that those u joints never pop right off like they should. congrats on getting it off.
NISTECH
Chris if you worked a week in california you would never go back to working on cars there. We are seriously spoiled here. our shop has a cutting torch but I think the last time it was used was to getto weld a piece of coat hanger on one of our bench vises to fix the stopper knob on the spin handle. that was a year or 2 ago.
On the exhuast campaign for the QR25's the sheild bolts usually just come right out too.
spitz7985
Car: HICAS S13
Well, I guess I know where I'm getting my next s13 from. The sea salt air doesn't cause any rust?
Thanks a lot for all the help, if you wouldn't have told me it was just one bolt holding it in, I would have been too scared to pound it off like I did. Thanks! If I was rich I'd donate some money to you (but I'm not).:pface
s13sr20chris
its all good. i really dont have that much of a corrosion prob here. its the cars from up north that have it bad. we just have a little rust here and there. just enough that pinch bolts dont just fall out:)
side note for nistech:well i finally got a break for putting up with the dealerships mess. i got promoted to blue team leader. PRAISE THE LORD! hope i can handle it.
NISTECH
Glad to hear you got it taken car of spitz, we do have some rust from the coastal towns but it is right on the coast that happens but even then its very minor. Not enough to make it that hard to get apart. Time to enjoy the fruits of your labor!!:thumbup:
congrats Chris. Its quite an undertkaing to run a crew ,alot of stress involved plus you are subjected to more of the buisness end of service which can add a heap of stress, at least thats the way it is for me at my dealer. Good luck and remember patience is a virtue..lol
gumby
Car: '89 240sx sohc
thanks for the post guys ill be doing this shortly if it ever stops *****ing raining. I'm waiting for noahs ark to show up. I never thought of the northeast as exceptionally damp until i started this project. what a friggin nightmare with the rust.
spitz7985
Car: HICAS S13
Hey, gumby, for the tie rods I used this special ball joint tool, its sorta like a clamp that has a bolt head that tightens it, you use a wrench on the bolt head to tighten the clamp. One end goes on the top of the tie rod stud and the other goes below the knuckle. I HIGHLY recommend getting ahold of one of these tools if your tie rods are even being a little bit stubborn. If you do get one of these tools, make sure you thread the nut on the top of the tie rod stud a little bit, so the clamp doesn't mess up the stud.
-Brandon
