steering column
gumby
Car: '89 240sx sohc
I need to disconnect the lower steering column ('90 240sx) from the rack to remove manifold, replace rack, install headers.
I removed the bolt below the lower joint. what does the bolt inside the cabin on top of the assembly housing connect to? Do i need to remove it?
sorry about the stupid question i tried search
NISTECH
I cant say I have ever had a 240 coloum out so i am not familier with the bolt you talking about. but you do not need to remove the coloum to remove the rack or r&r the manifold.
gumby
Car: '89 240sx sohc
i suppose not but i cant see separating the stock manifold. those suckers are fused. could use the extra space. I'd even disconnect the AC line too but id feel guilty about opening a new hole in the ozone layer. I'll see if i can pull it off tomorrow and report back.
NISTECH
I just seen you were in NJ so your rust is a bit more severe there.
Dont feel guilty about the freon stuff. FACT: each time the space shuttle is launched it is the equivalent of opening 50,000 R-12 Automobile A/C systems to the atmosphere.
Well....... that was before the atmosphere blew up the last one.
gumby
Car: '89 240sx sohc
the oil leak saved this chassis from certain doom.
Dattebayo
Im worried about this for my removal, taking place on friday.I hope MD doesnt get as bad rust as NJ, we are almost neighbors by way of ferry, you know.
gumby
Car: '89 240sx sohc
yeah i got the idea of disconnecting the steering column from another thread about hotshot installation before i dropped the manifold on it. DOH!!!
droll
I agree that you don't need to touch the steering column to get the exhaust manifold out. Having the A/C line out of the way does help, though.
gumby
Car: '89 240sx sohc
alright, its out. the steering column, engine, and ac line move just enough to wiggle it out. definitely a chinese puzzle and i dont think subjecting the steering column to those forces is good for its health, but i couldnt figure out how to disassemble it. wouldve preferred disconnecting it. hopefully no harm done.
what a pain
recommend cutting the aiv pipe as close to the bung as possible it catches on the column.
