steed77 »
https://forums.nicoclub.com/steed77-u138200.html
Wed Aug 05, 2009 2:12 pm
Sounds exactly what mine does too... I feel it's the factory car and the way it is. IMO the only real fix is mods....
I plan on correcting it using a few different methods. Typically I would START with tires and wheels. However the stock Conti's (suck) will be tested to see if the tires are actually this bad or it's the suspension. I may be a little backward than my typical mod route, but here it goes.
Here is my Mod list in this order. Springs (Eibach pro-kit)Struts.... not sure on brand yet.DC sports strut barmicroimageonline.com- full Versa set-up (R-sway, F&R under braces, trunk brace)Good alignment (have shims and bolts)
After that it should Fix the float and dive. IF not the only thing left is the crappy tires. So something in the 17 or 18in flavor. Probably do the GoodYear Eagle F1 A/S for tires. As I have run them on a few tracks and winter duities with great success
I am also adding an in several other areas(HP and tunes), but that is for another discussion.
