Also , http://forums.driftinginsider....t=459eDmSiL80 wrote:i have peak-performance tie rods on my car at one point. But i took em off cuz they would get TOO much angle and the outer tie rod would hit my lower control arm. I think i just need to re-center my steering rack. But theres a fine line with too much angle and a lot of angle. Suposly i hear the japanese cut the knuckles off the tie rods and reweld em to get even more angle.
Can you please do a write up with detailed pictures?eDmSiL80 wrote:i did that it doesnt work. But i run 18x9.5's up front. Only way to stop binding is to re-center ur steering rack if u have aftermarket tie rods and such. Im also doing extended tubes too, and they have a bump steer kit for that.
The best way obviously to avoid that is to center your steering wheel before the binding happens , but it doesnt always happen that way.eDmSiL80 wrote:I read a thread on ziptied of a big arguement of binding of the tires at full lock.
What he meant to "cut out" was a piece of steel that you have might have lying around in a shop or garage , then fit it between the stop and the control arm.eDmSiL80 wrote:i read the thread u posted, did matt mean cut part of the lower control arm? Just so the tie rod has room and doesnt hit it?
