sdtouge wrote:its f difficult to explain because you dont know what youre talking about
No need to be a d!ck , d!ck , you could've been decent and said something like "I dont think thats right slappy" , but no , you had to be a typical car forum c***......and what i mentioned does help , because i was just at MA last week.
Schuey7 time: exlpain to me one more time what that support weld does on the FLCA that you were showing me the other day
JDM Fresh: it braces the oem tie rod stop on the arm so it doesnt bend
Schuey7 time: does that help with binding or no?
JDM Fresh: yes in that if you have one bent stop that it will bind, so you make sure they are straight up and down, then weld brace on there then they are good
JDM Fresh: yeah
JDM Fresh: like
JDM Fresh: if one stop is bent on one of your FLCAs it will bind , cause it will go over center , reason you need to center your rack
JDM Fresh: make sure its equal or damn close to equal amount of turns form full lock left to full lock right
BOT
Brian from MA Motorsports is doing that mod as well.
http://forums.driftinginsider....=1328
Modified by Slappy at 2:04 AM 8/26/2008
