Jostudly wrote:When I get my winter rims and tires put on how much does it typically cost to get the TPMS valves taken off the stock rims and put on my winter one's? I would rather not have the TPMS light on all winter.
It's really not worth doing this for 2 reasons:
1) TPMS sensors should not be continuously installed/removed. Eventually, they will be damaged and cost $150 ea. to replace.
2) With the TPMS sensors are absent, your Rogue will continue to operate normally. It will not impact the ABS, VDC, etc. The TPMS light will automatically reset when you re-install the OEM wheels come spring.
So my suggestion is to do what I did:
1) Run your winter wheels/tires without TPMS sensors. TPMS is not an excuse to avoid checking tire pressure. Check your tire pressures at least once per month like you are supposed to.
2) Cut a 3/8" square piece of electrical tape to cover the warning light for the winter. Yes, sounds ghetto but you will not see either the tape or warning light once applied.
