Meantime »
https://forums.nicoclub.com/meantime-u7126.html
Tue Jul 08, 2003 9:47 am
All three of those springs are progressive. The S-Tech is not linear. Tein only lists the max rate for the spring.
The AGX warranty is void if you drop more than 1.5 inches over stock height. That's a good rule-of-thumb to use as far as "too low" goes. All three of those springs should be okay to use with the AGX. Sportlines drop the car pretty far, but people don't appear to have had any significant problems with them yet. If you want a bigger drop than these springs offer, like a full-blown RS*R spring, you'll need a shock with a shorter travel, like a KYB Buzz Spec.
Myself, I would opt for the PK, as I don't care for big drops. Handling-wise I would say the S-tech or PK are your best bet.
