Status Update - Craig's Q45
OwnerCS
This afternoon I reached the point where the plenum and the intake runners are being aligned before the final runner torque down.
I've been taking care of so many little details with this project. The bulk of the time spent has been for me learning how to DIY.
qship96
Car: 1996 Infiniti Q45
Looks Beautiful !!!!!!
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
That looks way too fancy to be under the hood of a Q45... LOL!! :)
BCC93QT
Car: 1990 Infiniti Q45
1995 Infiniti Q45
Im smaking myself as we speak for rushing my engine swap. Good stuff
Lokim
Car: 1994 Infiniti Q45 acquired 4/25/10 w/192K
Now at 222K and going strong!
Gorgeous motor, but FLUSH YOUR BRAKE FLUID!!! GOOD GOD, MAN! :nono: :bigthumb:
Q451990
Lokim wrote:Gorgeous motor, but FLUSH YOUR BRAKE FLUID!!! GOOD GOD, MAN! :nono: :bigthumb:
:spitout: Glass half empty kind of guy aren't we! With an engine that looks like that, you gotta feel like that's on his list :D
OwnerCS
Ok - Changed it last night.. The new synthetic brake is beer color though..Depending on lighting it might continue to photograph dark. :gapteeth: I was holding off till it could get it out of the garage as the rear is in a position where it is too close to the wall to get under it to bleed the rear brakes. So I still need to bleed the rear. The synthetic Differential and Power Steering fluids are purple..
The vacuum pipe to nowhere was stripped, powder coated black, and baked to provide corrosion protection at high temperatures.
The heater hose line comes from Infiniti nickel plated. It was buffed and polished using jewelers Rogue then coated with a high temperature clear ceramic coating and baked according to the heat resistance preparation procedure for prevent tarnishing and added corrosion protection.
Three additional protection layers were added to the knock sensor wiring harness for added heat and wear protection and to prevent interference from varmints.
1) Heat-reflective tape wrap constructed from a thin layer of aluminum foil heat-stable laminated to a texturized glass fiber base fabric.
2) Fire retardant automotive cable conduit.
3) Outer layer in a wrap tape that was originally developed for the military. It is made from a special silicone compound which adheres to itself when wrapped under tension. It won't melt up to 500°F(260°C), has a tensile strength of 600 psi and can insulate up to 8000 Volts while remaining flexible to -60°F (-54°C). Forms a Permanent Air & Water Tight Seal and stretches to 3x's its Length Conforms to Irregular Shapes.
An insulated line carrier was fitted to the knock sensor harness outer cover then secured on the center bolt [picture center].
The largest nylon wiring tie that would fit through the original wiring harness tie down hole was used to secure the harness to the powder coated vacuum line harness bracket [not pictured].
The water pump and water hose thermostat cover and housing in addition to the area between the cylinder heads were all were polished using a Dremel jewelers polishing brush then coated to prevent tarnishing and to provide corrosion resistance.
Here's a pic.. :chuckle:
goody90q45
Car: 1992 Infiniti Q45 (sold)
OwnerCS wrote:......3) Outer layer in a wrap tape that was originally developed for the military. It is made from a special silicone compound which adheres to itself when wrapped under tension. It won't melt up to 500°F(260°C), has a tensile strength of 600 psi and can insulate up to 8000 Volts while remaining flexible to -60°F (-54°C). Forms a Permanent Air & Water Tight Seal and stretches to 3x's its Length Conforms to Irregular Shapes.......
Sounds like silicone RTV tape, MIL-I-46852C or MIL-I-22444C. Great stuff. Works pretty good on the surface of Mars also. :biggrin:
I like using the orange tape, it makes the V8 look more like a rocket engine. The coil harnesses and MAF harness got a wrap on my engine.
OwnerCS
Excellent idea for the coil harness!
Now is the time to address that -- though seriously I don't need any more project scope creep as I'm messing up the supply chain for Wes who is patiently awaiting the delivery my ECU core...LOL
I finished wrapping the injector harness last night. It does make the harness look like the mummified hand of an extraterrestrial space creature.. :crazy:
Maybe our wiring harnesses will last until the next ice age.. LOL
Q451990
Armored harnesses... wow!
