Well put.nametakennow wrote:Over 300hp in a FWD car is going to be a handful.
Anyway, the 5spd itself isn't the issue with going through clutches, it's the clutch. A 6 puck with a heavy duty pressure plate should be able to handle that and be somewhat streetable.
300hp is going to be easier with the SR. One way to get there would be to find yourself a DET (Bluebird, Avenir, or GTi-R), use a T28 or T3/4 turbo and turn up the boost to 15lbs for starters. That should put you in the 270-280whp area, maybe a little more with a GTi-R.
This is all a matter of if you have the time and a bit of money to make it work.
