Stater harness 12 volt green power wire-QX56
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
noonooJAY
Car: 2005 QX56
I've seen diagrams that say this is a "consistant power" wire. Is this true? And, is it safe to tap into it right at the back of the white connector of the cluster that snaps into the starter?
dx3
Car: 2006 Infiniti QX56
noonooJAY wrote:I've seen diagrams that say this is a "consistant power" wire. Is this true? And, is it safe to tap into it right at the back of the white connector of the cluster that snaps into the starter?
Hey man,
Get a DMM. Stick one end on whichever wire you want and ground the other wire. If it reads 12v you are good to go. If not, try the next one. Jonny
Return to “Armada Forum / QX56 Forum / QX80 Forum”
