I don't see the dropping resistor listed. Have you checked it? Don't know if it throws a code, but mine crapped out, and the engine would turn over, but not fire. Replaced it, and it fired right up.Also, have you double checked your grounds?fivehunsky wrote:Update time..
Here is what I know:
150 psi on all four cylinders
35ish psi of fuel pressure
ecu is code 55
Mechanical timing is perfect
all plugs are firing
all injectors are firing
cas checks out
ignitor checks out
maf if functioning
You can reads no good?Dattebayo wrote:SO um, dropping resistor?
Bueler?
After reding this thing over and over, I'm convinced that I'm going to touch an area of concern for you. So you are using an S12 CA with an S13 intake manifold attached to the head, correct? If so, then you guys have a "Hard-Fail" because the S12's head is different on the intake port side than the S13's. You will be leaking vacuum all over the place and the car will never crank (hope it don't catch fire). You'll need to use the S13's head with the S13's intake manifold or you'll continue to post for help and I personally am trying to help clean this up on this forum. Hopefully this thread will help some new user who decides to go the route you went, failed, but wasn't too lazy to use the search function on this forum. It will now be archived and we can move on to other challenges.fivehunsky wrote:I just sent him a pm.. thanks for the info
Also, if the injectors are firing.. shouldnt the drop resistor be okay?
and I dont have a vac gauge in the car yet so I cant get a reading. I will as soon as I get the gauge in there tho.
I guess the main questions are:does the s12 ca det have the bearing girdle?
will the s13 intake work with the s12 engine?
do you have any ideas on why its not starting?
if worse comes to worse we are just going to put an s13 head on this bottom end. we have a couple laying around.. is there anything that will not work? ie.. wrong piston height/compression ratio with different heads/blocks..
Since you supposedly diagnosed your problem, there's no need to carry this thread on as you don't strike me as someone who really needs anyone's help. Good luckfivehunsky wrote:Umm.. huh?
Im not sure if you read the last few posts but I had already identified that problem. Thanks for.. um.. trying to help?
I have already decided to continue to use the s12 head.. I am just going to use the s12 lower on it with a custom upper made by autocomp racecars.
I am sorry if I am "dirtying" up your forum?
Feel free to delete the entire post if you want. I just thought that you guys might want updates on how things go. Im not the one who keeps posting about the startup problem.. Its people who havent read the whole post.
Anyway:
My plan of action is
A. build manifold: more fun alternative than swapping heads
B. compare index for cas on s12 cam to one on s13 cam.. see if there is a difference
C. once the intake is complete start over on diagnosis. If it works out I might start selling manifolds haha
AGAIN, FOR ANYONE WHO ONLY READ THE FIRST POST
THE S13 INTAKE DOES NOT FIT THE S12 HEAD.. I AM MAKING A MANIFOLD
THE END
