o0Syn »
https://forums.nicoclub.com/o0syn-u147531.html
Mon Mar 29, 2010 4:42 am
Hey everyone just looking for ideas as to why my truck is having problems staying running. It's a 96 D21 KA24e 2wd
I had it running when i was leaving a friends place and then it just snuffed out. I pulled off to see if i could get it back up. It starts for a few seconds then i hear a slight woosh of air then the engine just clocks out.
I have run injector cleaner and let it sit over night still nothin.
Pulled the snorkel and poured some injector cleaner into the intake to get it started, it will run a little longer i even got a few rev's out of it once before it fell on it's face again.
Pulled the fuel rail and barely any fuel is getting up to the injectors just a little drips out.
I have heard several ideas from friends that it could be either the fuel pump or some sort of inline fuel filter that's clogged or possibly the air flow censor?
So thats everything i can think of please help me out if you Nico Gods can! i used the teardown on here for my truck to replace the timing chain because i have the little knock of horror that guide was great and all of the comments after the post helped alot too so a I owe a big thank you to this community
