Starts then dies immediately
A forum for the Nissan Quest... minivan lovers unite!
dcjlawton121104
Car: 2007 Nissan Quest 3.5L
I have a 2006 Quest. It starts up and dies immediately. I have replaced all the injectors. The fuel pump is working. I checked the relays. I am a complete lost right now. I could use some help. Thanks man advance.
far raf
Car: 2005 Nissan Quest SE (standard? simple? edition - i.e. nothing special)
Did you pull the codes?
dcjlawton121104
There's no codes
far raf
Is this intermittent or does it die every time?
dcjlawton121104
every time
far raf
Did you check if the ECU housing is corroded through? If it is, you may have to get a replacement ECU. This is a common problem, as the ECU on the Quests is outside, in the engine bay. Folks on Questdriver forum reported many times they had all kinds of stalling issues due to ECU housing corrosion.
far raf
It just happened to me! I was working on the throttle pedal and had the position sensor plug disconnected. Forgetting about that, I tried to start and it died right away every time, until I recalled that the plug was disconnected. But I would imagine it should throw the codes P2122 or P2123 if TPPS was the reason. But it does not hurt to check anyway. Check the pages EC-655 to EC-669 in the FSM for the test procedures:
The voltages between the ECU plug terminal 106 and ground have to range from 0.5-1V (fully released pedal) to 4.2-4.8V (fully depressed pedal).
The voltages between the terminal 98 and ground have to range 0.25-0.5V (fully released) to 2-2.5V (fully depressed).
If you are not getting both voltages in that range the pedal sensor is a toast.
FairladyS30
Car: 2004 Nissan "Pathfinder" Armada
What did the problem end up being? I'm having the same issue.
Thanks
drgtr
Car: 2011 Nissan Elgrand e52 VQ35de CVT
Crank Angle sensor. Very common issue.
Us aussies cop it all the time in our E51 Nissan Elgrand vq35de
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
drgtr wrote:
Thu Jul 09, 2020 1:14 am
Us Aussies cop it all the time in our E51 Nissan Elgrand vq35de
:poke: Introductions / General Chat
How to upload pictures on NICOclub: Using IMGUR
Pictures can also be added as an attachment.
chefnee
Car: 2008 Nissan Quest SE
I had this happened to my 2008 SE. It turns out that the battery was on it's last leg (old and barely 3 years). I had a warranty on it and got it replaced.
Return to “Quest Forum”
