starts for 2-3 seconds
eastcoastchaos
Car: 95 240sx
finally finished with head rebuild and new head gasket. lots of screwing with timing and i've got it to start consistantly but it only runs for a few seconds then dies. weather i'm on the gas or not it doesn't seem to do anything. just crank start die. pleeeaaasssee help me i hav'nt driven her in weeks
eastcoastchaos
Car: 95 240sx
i did the ecu test after lots more screwin with the timing and came up with 11 and 21. crankshaft position sensor and ignition signal primary. what do those mean and how do i fix um. thanks
eastcoastchaos
Car: 95 240sx
allright now i'm thinkin maybe it is the ignition signal primary. is that in the distributor? anyhow to get my distributor in i had to tap it with a slide hammer. could that have broken it. what all would i need to replace?
eastcoastchaos
Car: 95 240sx
no more codes this morning. they must have fixed themselves. so what else. please help
hachibroku
Car: 98 240sx s14 MO Betta
check your oilpressure switch if it doesnt read pressure it wont allow the fuel pump to continue to run and it will only prime the system
eastcoastchaos
Car: 95 240sx
where is that. and i just replaced my o2 sensor b/c i did the test on the ecu and it showed bad o2 sensor. i can keep it running with the gas now but if i just let it run maybe 5-10 seconds at best, it starts out running a little fast then the rpm's drop it stutters then stalls.it's getting good spark, compression is between 180 and 185 all the way through and i think it's timed right now.
Nismo_Freak
Car: 89 Nissan 240SX
Re-evaluate timing.
Also, try unplugging your MAF. See if that allows the engine to at least idle.
eastcoastchaos
Car: 95 240sx
it idles pretty high but it seems smooth w/o the maf and it doesn't stall anymore it ran for a few minutes before i just turned it off.
the part of th MAF that has the wire seems a little screwed, there are four terminals and one of them doesn't doesn't have the metal female part of the plug. i think i'll replace her and see what happens. thanks
Nismo_Freak
eastcoastchaos wrote:it idles pretty high but it seems smooth w/o the maf and it doesn't stall anymore it ran for a few minutes before i just turned it off.
There are only 3 pins to the MAF.
You need to replace the MAF itself.
eastcoastchaos
Car: 95 240sx
is the junk yard a bad idea. these things are like 400 bucks new.
benemorius
Car: s13, s13, eg, e36
I wouldn't say the junk yard is a bad idea, but that's just my opinion. Seems like maf's are either good, bad, or dirty. Dirty ones get cleaned, bad ones get thrown away, and good ones keep working until they get dirty or until you mess them up while cleaning them.
Translation: clean your maf with carb cleaner, check the connections in the harness, double check it with a multimeter, and if it still is no good then get one from the junk yard that looks ok.
Nismo_Freak
eastcoastchaos wrote:is the junk yard a bad idea. these things are like 400 bucks new.
Alot of yards have replacement policies on parts like MAFs anyways.
But yeah, definately don't buy a new one.
