Dutch »
https://forums.nicoclub.com/dutch-u13957.html
Sat Apr 01, 2006 5:37 am
m problem may be solved... I found a hole in the vacume hose running between the egr diaphram and the egr solenoid unit,anyway, i replaced the hose and it seems to have fixed the issues. so far. The rough idle i had is gone and the car starts when warm now. Question,... Will the CEL come on if a sensor is bad? If so every time, it helps to diagnose problems connected to sensors but not the sensor itself. My engine light never came on.
