starting trouble ''lil'' black box
absolute
Car: racing,drawing,raping,games,girls
ok just to give back ground ive been swapping an kade man-tran , into a kae-auto, i got more time to jack with it and it turns over good and at the speed it should but no start. as i was going over stuff , i noticed the coil hadnt been connected, silly me right? wrong the harness i have for the de came with no connector that fit the coil for the kae. so i looked at the old harness found the plug and cut it off the old harness, found the corresponding colors on the kade harness but there was a lil black box that they went to "looks like a resistor box or something" along with two other wires. so i just snipped the two that i needed, green with black stripe, and black with red stripe, and connected them to the coil plug from the kae harness, i get some spark now just not alot, car still doesnt start. sooo......., is the black box needed, do i need to patch the other two wires in also..... do i need the coil from a kade.... help me here folks, im ready to put this show on the road..........
deviousKA
Car: 90 240sx NA /72 Datsun 510 NA /86 corolla GTS NA
The large black w/red stripe wire is main coil power, the little resistor box unit that sits next to coil on the harness is the resistor for the tach signal. Sohc that is
edit: this may be helpful
sohc ignition/coil tidbit from fsm http://www.hybridka.com/misc/ignitionsohc.jpg
couldnt find decent dohc schematic
absolute
thanks for the tidbit
absolute
hey devious hop on aim
