scooz14 wrote:i am going to want to get the most out of my n/a setup, but do not feel the need to do a stand-alone ems. i feel that an safc and a wideband will work just fine. my question is this, does the ka24e have a knock sensor, and if so, is there anything that will decode the signals?? if not im, going to have to find out some way to get a knock sensor hooked up.
SAFC is a hack and is weak, it's just as bad as using FPR for turbo's.
Look into nistune, or bikirom.
I know the ka24de has a knock sensor, but it's not really worth-while for tuning. I can hear knock long before the knock sensor goes off.
Just remember to tune from rich to lean (the stock ECU runs way rich uptop so you'll be taking fuel away anyways except down low.) I've had my car knock cause I've tuned it too lean or advanced timing and months later it's still running strong, just remember to get off the gas the second you hear knock..
Also with Nistune you can see if the knock sensor has been triggered. As far as aftermarket knock lites go they are mostly snake oil, seriously I've done alot of reading about it and have failed to see some one right a good review about them, they are either too sensitive and give too many false alarms or they aren't sensitive enough and you'll hear knock long before the sensor goes off.
I was all worried about not hearing knock or not knowing that I was hearing knock, but trust me, you'll know when you hear it if you pay attention to your car.
