starting to get on my nerves
kernan240sx
Car: 89 240sx
I will try to give you as much information as possible and hopefully someone can help me figure out whats wrong? My car has been starting up badly. . .
The Details
-89 KA24E 150,XXX miles
-in the morning after it has been sitting it starts up fine
-if it has only sat for about an hour or so and i go to turn it on, it will crank for a good 5-10 seconds before it finally starts up, and then when it does start up, it idles low and slowly reachs its normal idle (700-800). Sometimes when i start it, the car will shake for a little bit but it soon goes away.
-It isnt a huge deal because the car still is driveable, but it is kind of embarrassing and frustrating when the car cranks over for so long.
Modified by kernan240sx at 9:40 PM 3/9/2008
kernan240sx
Car: 89 240sx
i think im gonna give my car a tune up and see if that helps. been getting bad gas mileage too, so maybe one of my sensors stopped working?
240sxdrifter s13
Car: nissan 240sx s13
maybe your not gettin any gas try replacing the fuel filter but it could be what u said about the sensor
240sxdrifter s13
thats what happend to my car a couple of months ago but i changed the head gasket becasue it was blown and it fixed it
kernan240sx
Car: 89 240sx
im pretty sure its not a blown head gasket because my car runs fine, doesnt overheat and there is no white smoke after it has warmed up.
TDS
Car: 2008 G35
I had a similar problem a long time ago. It ended up being a loose fuel filter. Tightened up the hoses and it cranked fine ever since.
kernan240sx
Car: 89 240sx
Started my car up at school and it started up fine. Get home and 2 hours later i go to start it up and this happens . . .
http://www.youtube.com/watch?v=cccqz6btIYM
kernan240sx
Car: 89 240sx
please watch the video i posted above and leave me some input???? I want to fix this problem ASAP.
robinsone
Car: 1989 240sx
Dude I feel your pain, 89 240 230k miles. Alright first suspect would be the AIV, more specifically the IAA which controls the idle of the car. The its located on the back of the plenum. Find the throttle, the plenum is the elongated portion behind it that has ECCS or something written on it. Anyway on the end of the plenum closest to the fire wall sits the IAA, don't know the acronym, see service manual. The IAA is the specific valve that regulates the idle. The IAA also has a valve that regulates the A/C and boosts the rpms when the compressor cycles. The AIV is attached to the plenum via 4 bolts and a hose. its easy to detach. My guess is that its dirty. I cleaned mine initially with WD40, dumb idea, although it is a good de-greaser, just make sure not to immediately put it back on and start the car, you will understand the mistake I made as in fact WD40 is flammable. Anyway, try this it might work. What was happening to me was I having issues idling and kept cranking till I would flood the engine, so the car is probably running rich, and not getting enough o2 to get a spark. My car would stall in traffic at times. The real ***** for me was that I cleaned it and still had issues, turned out the valve itself was bad even with a cleaning. I still had a idle issue and figured out that it was I had a bad engine temp sensor which also plays a role in the idle. Beyond that it wouldn't hurt to replace the fuel filter, check the rotor and dist cap, looks like you have new wires, or course hopefully your plugs are good as usually they aren't the problem. I just had a problem with the MAF, mass air flow sensor sp? and switched it out along with an injector. So, with the high mileage early 240s a lot of them have an idle problem. Alternatively, I would clean out the throttle body and plenum with injector cleaner, this also helped the idle a little bit. Don't bother with Auto parts stores hit the junkyards as the prices are ridiculous and not worth it. I'm actually running a '93 AIV on my 89, just had to buy a longer hose to connect them. Check similar year Stanzas they have a lot of interchangeable parts. I have an extra AIV I could give you as I noticed these parts missing even in junkyards. Also if you don't have a service manual, its huge like 1000 pages, GET ONE!! mine was $60 like 6 years ago, I think they're on EBAY for $10, WELL WORTH IT. You can actually run a diagnostic using the ECCS or ECU, basically the brain of the car. Sorry for the novel, but this should give you some help, or check this site for other problems http://www.240sx.org/faq/
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
Sounds to me like you're getting too much fuel when warmed up. Coolant temp sensor is prime suspect. If the ECU is reading the engine temp as cold when its hot, its going to dump lots of fuel on startup. Add to this your poor gas mileage. Read the FSM for test procedures, or just replace it cause its cheap.
kernan240sx
Car: 89 240sx
all right, thanks for all the help! I will try to update when i find out what was wrong, that way it will be helpful for others.
