roundrocktom »
https://forums.nicoclub.com/roundrocktom-u6673.html
Thu Apr 24, 2003 7:11 am
No problem.
I really prefer the FSM (Nissan) as they will have the best information on specifics like the wiring harness.
The later Chilton's improved, but they will contain 50 million wiring diagrams. Problem is they will not be correct in all cases. I wouldn't put it pass them to state '89-97 240SX wiring diagram, yet it is only covers '92-'95 automatic's.
Alas, 25 years ago I LOVED Haynes manuals for being good common sense manuals. The Datsun PL510 (FSM) manual would state "remove seal using tool #xxxxx-xxxx" The Haynes manual would have "use a screw driver with a bent tip and yank that seal loose". Chilton would show a picture of a V8 Chevy engine and no seal! :rolleyes
Sadly the Haynes manuals seemed to get worse in the 1980's, Chilton's improved (yes, pictures of the actual vehicle!), but the Factory Service manuals are hard to beat.
You do need to use common sense on their "trouble shooting" diagrams... as those diagrams cover the most common faults (i.e. what happens 90% of the time when you see this error). Quite often you get to the end of the trouble shooting diagram to only discover "replace ecm"... catch is the ECM was fine, but when you noticed a bad TPS (reading too high)... and started to trace it, you discovered a bad horn wiring back feeding 12V onto a line that should have only had a 5V reference on it.
I've since "retired" from automotive wiring stuff, but enjoy the challenge of things that are normally unsolvable. Ya, still help out a buddy who owns a shop, but by the time I see something it is really strange!
Tom
