hi guys....im new to the forum...in fact this is the first forum iv joined so im new to the whole world of forums!!!!!though iv read plenty its now time to starting asking questions......i
would like to get a furmula for building a ca18det to handle 350kw atw reliably....i know it can be done
i chose the ca over the sr for block strength mainly amongst other things....so would like to know what will need to be done to achieve this.....
things on the list already are as follows:
godspeed rods with acl bearings and arp bolts
cp or weisco or wassner? pistons 8:5:1 or 9:0:1 ratio @ 83.5 bore
cometic head gasket
arp main studs
block cleand bored and honed
head shaved if needed
crank bearing journals ground if needed
new oil/water pump
560 cc denso or sard injectors?
bosh 040 feul pump
i would like to know what turbo to use that will give nice linear curve from as low in the rev range as poss and keep pushing through to 8500 rpm also what else should be done to acheive as much torque as poss at 350 kw @ 6400rpm.....thanks guys and keep the ca alive
