Nismo241 »
https://forums.nicoclub.com/nismo241-u392.html
Sat Jun 28, 2003 10:57 am
You need to pick up your tach signal and temp signal from the ECU, same goes for your oil pressure and boost gauge. But the only way to get the oil pressure and boost pressure readings is to use the two sending units that came with the clip. The speedo cable cannot have any tight bends in it or it won't work right. But what I did was, run a wire directly from the ecu where it picks up the tach signal and ran it to the wire in the plug marked TAM. The rest is minor stuff really, talk to Apex_7, he has it too, actually I took mine out and went back to the stock 240sx one. BUt he still has his.
