Simply put, your car is not charging and this is usually a failed alternator.beans33 wrote:Hey guys the car has been running just fine. Last night under normal driving the headlights start to flicker on and off every couple of min. The cd player also cuts off and back on when the lights flicker. I come out this morning and it wont start. Everything is has power but it wont even turn over. ive looked at everything and looks fine. Any ideas
Modified by beans33 at 10:51 AM 9/30/2008
I just bi-passed it with a bolt.ks13 wrote:thats actually good for your throwout bearing...not having the clutch pressed in on cold starts all the time.
better off leaving it out, or have it so you have to use your foot to press the button rather than the clutch.
wordboost_boy wrote:Simply put, your car is not charging and this is usually a failed alternator.
Dee
