TwistedRoads »
https://forums.nicoclub.com/twistedroads-u134544.html
Mon Mar 07, 2016 2:16 pm
99 Maxima Cranks and Cranks. Sometimes it starts. Guys this forum has kept my Max running for 10 years, and I am thankful. But this new problem has me stumped. I have searched and read for days and now have to ask for some help. Here's a list of what's been done so far.
1) New Battery and Starter. 2) Removed and cleaned all Battery connections and grounds. Added new ground to transmission bolt. 3) Followed FSM instructions for Fuel pressure and regulator All Checked Good. 4)Followed FSM for Crank position sensors and wiring and visually inspected tone rings on the flywheel and front balancer, no chipping observed. 5) Checked Coil packs and wiring all is good. 6) Changed Ignition switch with a new one. 7) Swapped in a Known good MAF. 8) Tried other keys and the problem is the same. 9) Took one coil pack and old spark plug grounded to engine while helper turned engine over. No spark and after several tries when spark is observed engine starts immediately. It just isn't getting the signal to the coil packs regularly.
Is there something im missing? Maybe ECU? or Ignition Key Switch?
When the car starts it runs fine. Only code has been P1335 and P1336. I have another Maxima and have taken any suspect parts one at a time and put in that car to eliminate a bad part. Of course my other Max starts perfectly with these parts in. I would like to keep it running a while longer. Thanks in advance.
