somgaet »
https://forums.nicoclub.com/somgaet-u143961.html
Thu Jun 23, 2011 9:34 am
I figured out my problem!!! After posting, I decided to go out with my meter and shoot some more wires. Everything checked out good and I was scratching my head. I finally decided to take out the brand new ignition switch and check it without the key/lockset part. The continuity checked out good. I plug it back in and try to start the car straight from the ignition switch...Wouldn't you know! It starts every single time. Doesn't skip a beat! I stuck the ignition switch back into the key/lockset, tried to start and it wouldn't. Pull it back out, and start straight from the switch and I'm good to go! The catch is, until you get a new key/lockset part, you still have to put the key in and turn it so that the steering wheel and shifter (auto) unlocks. Other than that, start your car, put the key in the key hole, and turn... then you're good to go!
