Starting problems
Shepy
Car: 1990 fairlady 300zx n/a 2+2
I recently had a flat battery on my 300, bought a new one and by the stupid of mistake
wired it up incorrectly, I didn't turn on the ignition as it didn't fit right anyways so swapped it in for a new battery a that is correct and wired it up the right way round, nothing is happening, does anyone no what the damage probably is, read that most of the time it's a numbed alternator or a popped fuse?
TellarHK
Car: 1994 Infiniti Q45
1995 Jeep Wrangler
1990 Nissan 300ZX
I'd say you just identified two things to check on first. Electrical's tough to diagnose online, unfortunately. I'd see about having someone test your alternator after you check all your fuses.
robomatic12
Car: 1990 300ZX TT
Check the main battery fuse located right infront of the battery. Theres a litte fuse cluster with like 4-6 fuses.
Shepy
Turned out 2 be one of the fusible link fuses had blown (bluddy lucky)
