Starting Problems
Novalou
Car: 1990 240SX
I have 1990 240sx with KA24e and M/T. Sometimes it will not start without me holding the throttle about half way open. Other times it will start without me doing a thing, but will usually want to die if I don't give it a little gas for a few seconds.
I was looking under the hood for anything obvious and I noticed the tube connected directly to the front of the TB has cracks in it; could this be the problem?
Thanks in advance for any help.
Valett85
Car: nissan 240sx se (93 240sx se and 95 240 sx se)
that is a cheap and easy fix. it is possible because it would cause a loss in vacuum. just fix it for a few bucks and see. if not you didn't lose to much and fixed a problem anyway.
Valett85
that is a cheap and easy fix. it is possible because it could cause a loss in vacuum depending on which hose it is. just fix it for a few bucks and see. if not you didn't lose to much and fixed a problem anyway.
Novalou
Car: 1990 240SX
I replaced the rubber hose in front of the throttle body and things where better for a little while, but then the problem starting reacquiring.
If you guys can give me some ideas of what to try next I would appreciate it.
Thanks.
