AHall »
https://forums.nicoclub.com/ahall-u1714.html
Mon Jan 05, 2004 2:36 pm
I have a problem with my 1993 240 not starting. The problem started one night when I was leaving work and my car would not start, all I got was the characteristic clicking noise. I was able to get a jump and drive home. The next I began to investigate the problem. I checked the battery and the voltage is good. I even took the battery to two independent places to have it checked and it tested good at both places. I checked the blue relay next to the battery and it passed the continuity test for no voltage applied as well as with voltage applied. The starter has voltage at the terminal equal to that of the battery. I have a lifetime warranty on my starter so I took it to the place for testing. They informed me that they do not do testing and simply gave me a new starter. (I know seems odd.) I put the new starter on and the problem continues. All I get is a clicking noise when I try to start the car. I can jump start the car successfully every time. I even jump started the car with no battery, disconnected the jumper cables and let the car run for 30 minutes with the lights on, radio on and heat blowing to see if the alternator was the problem. The car ran fine. I actually purchased another battery, but no change. The clicking continued. I then replace the new battery with the battery from my wife's car and tried it. Again no improvement. The terminals on her battery are opposite to mine so I had to really stretch the cables. Again no change. I then installed my old battery and the car has started fine for the last two days.
Any suggestions? I do not have a good feeling about this fix, as I do not know what was the cause or why the car now starts.
