starting problems please help
jason redtop hatch
Car: 1993 240sx redtop sr20det
i have swaped a redtop in my s13. i have fuel and spark but only to one cylinder, the first cylinder. i have checked the coils and ignitor and they seem to be fine. what could be my problem?
rotorimp
Car: 02 Xterra, 60 IH Metro
If your sure that you only have spark and fuel on #1 then it has to be a wiring issue--was your harness cut? start at the ECU and work to the motor. are you sure that the injectors are not firing on any of the other cylinders?
