300freekzx »
https://forums.nicoclub.com/300freekzx-u68103.html
Sun Feb 20, 2011 7:52 pm
Hi guys I have been away for a while but I am back and have a problem. A few months back my car just stopped cranking. I had to roll crank it to get it home. This week I got around to working on it and this has became a nightmare. I bought a new starter because the other was only reading 70 amps. put it on the car and no crank just a click of the starter popping out. Took the starter off and tested it and it works. Put the starter back on and once again click but no crank. Unbolted the starter (connectors still on) ran the neg. jumper cable from the battery post to the housing of the starter and it works therefore, I know that there is no shortage in the car wiring. Bolted everything up and tried to crank just click but no crank. I know you are saying seized motor but motor runs fine. My buddy and I pushed my z out the yard and pushed it down the road I jumped in popped the clutch cranked and drove the car. We let the car sit (idle and running) for 20 mins and when I turned the car off we are back to the click but no crank. What do you think?
