jdm_master_X wrote:whoa calm down calm down.
check the temp sensor first. things happen randomly, so its a good place to start. i would also check the wiring to the injectors and make sure that it isnt shorted causing the injectors to continuously spray. what kind of fuel pump are you running?
Thanks for the info man. I'm currently running Walbro 255. The last owner had this pump already installed when I bought the car..... and when he soldered the wires toghther, he just used electrical tape to tape things up instead of using heat shrink......so, the adhesive melted and the tape came off...... talk about being dangerous. Anyway, I just got the new sensor today. I'll try and post the results.
thanks
