InsanityInc »
https://forums.nicoclub.com/insanityinc-u19073.html
Sun Sep 19, 2004 2:37 pm
I see... Would it be possible to shove a thin wire into the plug and then attach the harness without the wire breaking? Also, would a tiny wire like that be able to carry enough voltage?
I don't really think it's the cause of the problem, considering I moved the TPS around to a bunch of different places, and it still did it. Though I figure it can't hurt to make sure it's set right.
My car has an exhaust leak, is it possible that the exhaust leak is somehow causing the problem? I have a cone filter and the leak is at the header/PAIR valve connection, so It's possible the exhaust is recirculating into the intake, or the leak itself is somehow causing it...
I'll try and describe how it starts up a little better, as well:
You crank it, it goes for a second, starts up. Jumps to about 1100-1300 rpms for maybe half a second, then it starts to drop, hangs at 700-800 for about a quarter of a second, then keeps dropping. Occasionally, it will start if I don't give it any gas, but it's still really rough, because it gets down to about 400 rpms, but manages not to die, then it comes back up.
