BUMP. Okay, so turns out there was more to my "starting problem." After replacing most of the vacuum lines, checking the fuel pump and what not, I decided to do my daily start-up. I put the key in the ignition and turned it to the on position and the wipers and warning lamps came on as usual. But when I went to start it, it cranked once and it like, died. After that, I turned the key and it just clicked, then afterwards, just one click
Then later today, I went to check it out again and this time, no clicks at all
I charged the battery real quick to see if the battery was bad and I let it sit for a couple minutes and then I turned the key to on and the warning lights came on, so I know the battery is good
I have a feeling it's the starter... But I'm going to give it a full charge tomorrow after I charge the charger to see what the problem could be haha.
So if there is anything you guys would suggest that would solve my problem/s that WON'T clean my pockets out, please do so. I appreciate the help
