Skibane »
https://forums.nicoclub.com/skibane-u40096.html
Tue Apr 12, 2011 6:32 pm
On the Y33, there is no "starter relay" per se - Apparently, it was omitted as a cost-cutting measure during the redesign from the G50.
The current flows from the ignition switch through the Park/Neutral transmission selector switch, and then directly to the solenoid mounted on the starter.
My 2000 occasionally does exactly the same thing - and has been for several years. I'm not convinced it's the starter itself, since it spins the very next time I turn the key - Typically, if there's a bad spot on the starter commutator, it won't spin again unless you whack it with a hammer. My prime suspects include the solenoid, and the transmission selector switch.
